I think you might be a little late
Am I? Please screen shot and send to me where it says sold
Lol I just doubt he has the same pack laying around a year later
Againā¦ please show me where it says sold. Better to inquire than assume.
boom
10 chars
Yea man itās more than likely gone a year later
not sure why this made me laugh so much
Fair enough. Just figured Iād ask.
Still quite a noob here. Sorry in advance Can anyone help? Do I have anything to worry about here (aside from the obvious. Clearance under deck, insane top speed etc) Iām running a single 190kv 6374 SK3, Torque VESC, 90mm wheels, 16:32 gears and I just ordered 2 6s 8000 mah lipos Iāll be running in series. Iām upgrading from 2 3s 5000mah lipos in series. Anything other than changing battery voltage cutoff start and end? Do I need to re-detect motor? Set any other parameters? Just wanna make sure I donāt damage my VESC or any other components. Thanks in advance anyone!!
Hi Bert, I wasnāt talking to you bro Try using the search function for specific questions or for quick and dirty little questions try asking them in chat. As a last resort start a new topic, to get the best response show you have done your research and you are not looking for other people to do all the work for you: you just need some technical help
Thank you sir!! Iāve tried searching for an answer for my specific setup. Theoretically I should be fine Iād just like a seasoned pro to confirm ya know? Thanks for the tips!
IT is sold yes.
Only issue I see with that setup is you will go over the 60k eRPM limit of the VESC. At 12S youāll be at 50.4v on full charge, which puts the theoretical RPM of the motor at 9,576. Assuming a 14-pole motor thatās 9,576 * 7 pole pairs equals 67,032 eRPM. Not 100% certain that limit still applies (may have been fixed in the firmware, not sure) but people still talk about it as if it does so Iād be careful if I were you because if it isnāt fixed your DRV chip will blow.
Thanks for the response. I thought about this but wouldnāt setting my limit to default at 60,000 prohibit it going over that?
Yea but itās crazy inefficient
Inefficient as inā¦overworking components? How so?
Inefficient as in your motor is only running at 70% if itās max efficiency when you do that, less range, less power
Ahhh okay. What would you recommend to remedy this?
Really you canāt do anything other than getting a lower kV motor or lower voltage battery
What if I ran dual VESC and dual sk3 6374?
