After starting off with a koowheel, then going to an Evolve BGT, I decided to go the infamous DIY route. I built a single motor 6474 190kv 10s lipo build earlier this summer and the brakes/torque just weren’t there. Ya it went 28-31mph but the brakes were awful and in the end dual motors/vescs run 10x more effiecient.
TB 6374 190kv motor $120 ( x2 ) = $240
TB 12s4p battery (included charger, on off, voltage reader ,enclosure and is a xt90 plug) $450
TB VESC 4.12 = $99 (x2) = $200
TB 218mm trucks = $60
TB motor mount pulley kit 16/36 abec $99 (x2) $200
Deck ( Method longboard deck ) cut, sanded, stained and ployunrathane the outside. = $65
Wheels = Abec 11 97mm = $100 or clones $28
Nano remote = $25
Male to male service = $3
VESC canbus =$2
Vesc connector = $7
Hardware for deck and bolts for enclosure = $20
Shred lights = $40
After discounts and if you get clones instead of abecs you can keep this build within $1250-1300 which is crazy for the specs
This board goes around 42mph. Super windy ride today but this dual 6374 12s4p thing is a beast compared to my evolve.
Yes only bldc for me. I blew one in FOC about a week ago but I was being a dumb ass. Tried smoothing out MBS wheels Kaly style which doesn’t work on 12s. I’m going to run hybrid soon
Have you tried censored BLDC? I have a build similar to yours, but on TB vesc and one Ollin Vesc. I tried running sensored BLDC and it was a lot louder than unsensored, but only on the TB vesc, the Ollin board vesc had no increase in noise. Wondering if it’s unique to mine or typical of all TB vesc
My build which is similar to yours, I topped out at 35mph. Different brand motor/ESC but I limited erpm to 60k. Also unknown to me at the time my remote was only giving 93% at full throttle. I’m using maytech 6374 190kv and dual focbox. So maybe further testing is required to see if I can find another mph or two
Ya that’s weird, I’m 200lbs and I don’t even have ceramic bearings. I just have some abec 9’s. I have the same hearing as well with 12mm belts. What’s your vesc settings?
