My old build is here.
It was good for about 6 months but now it is just too slow and doesn’t have nearly enough range. To fix this I am going to get these batteries. Right now I am planing on having a 10s10p battery. The only problem is I don’t know how I would charge all of them at the same time. Can someone please help me with this? Thanks!connect all of them in parallel. charge that way. you just need to splice the discharge leads into a charging port and your all set
Are the discharge leads the black wires on the bms jst connector?
There’s 1 connector to use, the xt60, that is all
the discharge leads are the ones with the connector on them
would I just use a hobby charger with an xt-60 connector?
You can use any 42/36 lithium charger
I’m confused. So I would splice all of the Bms Leads?
No, don’t touch the BMS at all You’re dealing with 1 connector the xt60, forget the BMS exists
You just combine the xt60s that is IT
yea. what scepterr said.
I’m talking about the main thick wires that lead to the xt60. the same ones you would plug into the vesc
So just hook all of them in Parallel and charge through the xt-60 connectors by adding a charging port ?
Yes, it’s that simple
exactly 10chars
Lmao thanks guys I feel stupid now.
just letting you know…
10s10p is gonna be heavy as FUCK. 10s6p is 7 pounds. my guess is that 10s10p will weigh around 13 pounds
It’s all good, you got it now
I would deff suggest a 5A charger to charge 20Ah …that’ll take like 6hrs
he explained the exact same thing to me lol. took me a bit longer to comprehend though
Hooking these up is so simple it is facepalm worthy
Yah I know its going to be heavy but I’m planning on buying 5 of them becuase I would rather have to much range than not enough because I am tired of my board dieing.
I set aside like 4 hours the day I got these to wire them. took about 30 minutes to get a completed pack lol
