BRAND NEW (the one pictured is the one that will be used on my e-mtb; you will get one in a sealed package) 100 amp over-current protection 20 amp continuous over temp cut-off sensor built in power switch 55mmx 55mm x 21mm I’m looking to get $55 for it. Free Shipping CONUS.
Let’s try and keep on topic here. If the OP wants, we can delete previous posts.
Seems a bit low to me?!
you could bypass output and use for charging/balancing
With 10S = 36V, 20A is still 1200 Watts of continuous power.
36 volts at 20 amps is 720 watts of continuous power.
You know that feeling when nothing goes right with your day . I’m experiencing it right now.
Yes, 720 Watts.
Then i do not need such an expensive BMS. I could buy the 15€ BMS from ebay for charging… This BMS here has also a soft switch which would be without use
