I’m building a board and using motors that have 10mm shafts i need to find drive gears with 10mm bore. Any suggestions where to buy such gears. also is it not possible to ream out 8mm gears to a 10mm bore? thanks for looking
There are others out there also. Maybe someone has extra laying around
Do you talk about spur gears or HTD pulleys?
You can drill out 8mm to 10mm but be careful, .1mm off and it’s gonna wobble like a brick wagon. Better to just buy 10mm bore pulleys.
I think with a good sharp bit and drill press Ithe should be ok
