I have a pair of tb218 trucks I just really wanted to use these rims on 10mm trucks specifically for speed testing
I found some but they cost around $8 a bearing that would come around $64 for a set too much may be later when I know there is no other way as for now thought of some 6901-2rs with a conversion spacer
I remember reading somewhere that the wheels have a max rating of 30 km/h so I wouldnāt push them too hard. Iāve taken them up to 40 km/h but only for short bursts.
Nice idea. Some 10mm ID x 12mm OD (1mm thick wall) stainless steel tubing could work well. Alternatively you could sell the wheels on the forum and buy a set which have the correct 6000RS bearings you need. Airmail from HK/China will take a while though.
EDIT: I just checked and 6901-2rs bearings have a 6mm thickness, compared to the 628 bearings 8mm thickness. This could cause issues.
If the case of the 30km/h is true im probably going to use them on my kids board or sell them on the forum. They are still on 97mm flywheels and the streets out here suck. I did want to go fast like over 30mph but if these wheels canāt handle that ill stick to the urban threads.
Did you use the original screws that came with the rims? If so what type are they because I measured them at 5.8mm but not sure if they are m6 or not?
The screws are M6. I kept the originals on the front wheels but needed longer screws (with longnuts) to hold the pulleys onto each back wheel.
where to buy such a remote control? my remote contro stopped seeing the skate
Any one tried this for the replacement wheels evolve all terrain 175x30
