Hi! Here’s my new e-mtbd :
I wanted to put the ROXXY ESC as close as possible to the Lipos, so as to avoid fireworks to my left ankle. I also added YGE Caps.
So as to drill the box precisely, I printed 1/1 scaled patterns made with PowerPoint and glued them to the box (UHU school glue).
I built my “Fused XT90-S Anti-Spark Loop Key” with some piece of LITTLEFUSE 100A.
I listed everything I needed for this build :
ROXXY BL CONTROL 9120-12 OPTO : 73,4 x 56 x 31 mm 2 pc(s) https://www.der-schweighofer.at/Drehzahlregler-Roxxy-Bl-Control-9120-12-120-150A-Opto-a73758
YEP 20A HV (2~12S) SBEC w/Selectable Voltage Output : 56 x 25 x 80 mm 1 pc(s) https://hobbyking.com/en_us/yep-20a-hv-2-12s-sbec-w-selectable-voltage-output.html?___store=en_us
YGE-C9 YGE Caps Typ 9 2 pc(s) https://www.freakware.de/p/yge-cap-s-9-yge-c9-a50870.htm?slpos=a1-2864880
Embase de fixation HellermannTyton 151-10916 noir 2 pc(s) http://www.conrad.fr/ce/fr/product/542323/Embase-de-fixation-HellermannTyton-151-10916-noir-1-pcs/SHOP_AREA_27898
Traversée de câble HellermannTyton HV1207-PVC-BK-M1 633-02070 Ø max. 6 mm PVC noir 6 pc(s) http://www.conrad.fr/ce/fr/product/544485/Traverse-de-cble-HellermannTyton-HV1207-PVC-BK-M1-633-02070-max-6-mm-PVC-noir-1-pcs?ref=searchDetail
Multirotor XT90 Connector Fixed Mounting Board 1 pc(s) https://hobbyking.com/en_us/multirotor-xt90-connector-fixed-mounting-board.html
Vis cylindrique TOOLCRAFT 888735 2 pc(s) M3 6 mm tête cylindrique 6 pans intérieurs acier inoxydable DIN 912 http://www.conrad.fr/ce/fr/product/888735/Vis-cylindrique-TOOLCRAFT-888735-1-pcs-M3-6-mm-tete-cylindrique-6-pans-interieurs-acier-inoxydable-DIN-912/SHOP_AREA_19749
Écrou hexagonal TOOLCRAFT 888118 DIN 934 M3 2 pc(s) http://www.conrad.fr/ce/fr/product/888118/Ecrou-hexagonal-TOOLCRAFT-888118-DIN-934-M3-10-pcs/SHOP_AREA_19749
LITTLEFUSE 157.5700.6101 - Fusible automobile, Chariot élévateur, Action rapide, 100 A, 48 V, Série 157.57 http://fr.farnell.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=-2&urlRequestType=Base&partNumber=1354647&storeId=10160
Turnigy Aerodrive SK3 - 6374-192KV Brushless Outrunner Motor 2 pc(s) https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6374-192kv-brushless-outrunner-motor.html
Turnigy Graphene 6000mAh 6S 65C LiPo Pack w/ XT90 : 175 x 68 x 48 mm 2 pc(s) https://hobbyking.com/en_us/graphene-6000mah-6s-65c-w-xt90.html
S-Shape X-Lander II « Bamboo Edition » 1 pc(s) http://www.x-shape.fr/en/shop/freeride/x-lander-ii-bamboo-edition/
Hammond 1555V2GY 1 pc(s) http://fr.farnell.com/hammond/1555v2gy/coffret-watertight-pc/dp/1877073
Traversée de câble HellermannTyton HV1402-PVC-BK-M1 633-04020 Ø max. 6 mm PVC noir 1 pc(s) http://www.conrad.fr/ce/fr/product/541941/Traversee-de-cable-HellermannTyton-HV1402-PVC-BK-M1-633-04020–max-6-mm-PVC-noir-1-pcs/SHOP_AREA_27898
INSERT À VISSER ZAMAC M6 X 13 SERBOIS 2 pc(s) http://eshop-simaf.com/fr/insert-a-visser/109-insert-a-visser-zamac-m6-x-13-serbois-quantite-sachet-20.html
VIS METAUX BHC A EMBASE/COLLERETTE 6X25 INOX A2 2 pc(s) https://www.vis-express.fr/fr/vis-metaux-bhc-tete-bombee-empreinte-hexagonal-creux-avec-embase-inox-a2/18478-vis-metaux-bhc-a-embase-collerette-6x25-inox-a2-8406602518.html
RONDELLE CAOUTCHOUC 5X24X4.5 4 pc(s) https://www.vis-express.fr/fr/rondelles-caoutchouc/33217-rondelle-caoutchouc-5x24x45-5943052416.html
Collier de fixation pour plage de Ø: 17.50 mm (max) HellermannTyton 211-15130 argent 2 pc(s) https://www.conrad.fr/ce/fr/Order.html?tracking&code=1963497894&orderBy=&orderSequence=&fromDate=&toDate=
FS-GT2B 2.4G 3CH Radio Model Remote Control Transmitter & Receiver https://www.tomtop.com/p-rm318.html
300mm graphène Batterie Strap 1 pc(s) https://hobbyking.com/fr_fr/300mm-graphene-battery-strap.html
VERTIGO TRUCK - 12MM HOLLOWED & HARDENED STEEL AXLES WITH ANODISED BASEPLATE 2 pc(s) http://www.trampaboards.com/vertigo-truck–12mm-hollowed–hardened-steel-axles-with-anodised-baseplate-p-11150.html
SUPERSTAR 8 INCH WHEEL - MATT BLACK RIM WITH SILVER ANODISED SPOKES & BLACK ALPHA 8 INCH TYRES http://www.trampaboards.com/superstar-8-inch-wheel–matt-black-rim-with-silver-anodised-spokes–black-alpha-8-inch-tyres-p-408.html
TRAMPA RATCHET BINDINGS - ARMY CAMO STRAPS ON BLACK FOAM BLACK L BRACKETS & RATCHETS http://www.trampaboards.com/ratchet-bindings–army-camo-straps-on-black-foam-black-l-brackets–ratchets-p-10900.html
TRAMPA HEEL STRAPS WITH BLACK RATCHETS 2 pc(s) http://www.trampaboards.com/heel-straps-with-black-ratchets-p-10273.html
E-TOXX DIRECTDRIVE mailto:[email protected]
Innotec Total Power Grease Grease Spray 500 ml https://www.amazon.de/gp/product/B0058BTM2I/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
WD-40 1810035 Specialist Lubrifiant Sec avec PTFE 400ml https://www.amazon.fr/dp/B007JIB410/ref=asc_df_B007JIB41047443260/?tag=googshopfr-21&creative=22698&creativeASIN=B007JIB410&linkCode=df0&hvdev=c&hvnetw=g&hvqmt=
