Except, for hubs you have to replace with alike, and availability is kind of terrible.
Lots of belt drives are behind the rear truck as well so they are sheilded from debris.
i find that both inward and reverse mounting on the rear truck results in the same wear and tear from debris
Front truck mounting, however, protects it from almost all debris
Interesting, my boosted had all kinds of motor knicks and scratches, where as the rear mounted motors on my trampa and evolve GT are scratch and dent free free after hundreds of miles. Maybe its because they both typically have the AT wheels on them? Any idea why your front hanger protected your motors better than the rear hanger?
Yea probably because you were using AT tires. Also the angle of my reverse mounts is a bit shallow so they’re closer to the ground.
Do you know if they have issues with PU wheel slipping or coming off? Have you been able to get a pair of these yet?
They took too long. Picked up some maytech hubs instead.
Hey can you give your opinion on the Maytech hubs when u get it? I’m assuming that you got the 90mm ones. Thanks
gonna be a while until I use them, still waiting for other parts.
