Again I am not an EE, but when I look at the diagram I see battery voltage coming through the fuse, then through the 1M resistor @ R1. So in my case 50V fully charged, V = IR so V/R = I or 50/1M = 50/1000000 = 0.00005A @ 50V When you flip the switch it changes the gate of the mosfet from ground to battery voltage.
Now this is my understanding. I would love for someone with more electrical design knowledge to tell me I am correct or not and explain why so we can all learn.
I dont know if this is the correct diagram? I know for sure that D2 is outputting only 12V. I have also measured it on my vedder anti spark switch and it shows 11,7V
@michaeld33 I was assuming with my switch that we had to account for a high voltage and low amps but now that I know that you can go with a low voltage for the switch, the ebay ones should work fine.
Hello all. Thanks for the suggestions. I think I’ve come to the conclusion that buying one from DIY’s site is the easiest, as it’s already got everything included. My question is, will it work well with 10s? I think it should…
It looks almost the same, if not exactly as the one on DIY’s, and it’s a little bit cheaper to get it from the esk8 market than it is from DIY’s,and being on a budget, and conversions from USD to AUD, I’d like to save as much as I could, every dollar counts here.
