As I’m starting yet another build, I’m considering to sell my small Mall Grabber build. You can see detailed specs and build procedure here (scroll down in that thread to see latest upgrades), but to sum it up it features:
Single drive SK3 168Kv
esk8.de VESC 4.12
Enertion Trucks painted black
Orangatang Kegel in purple
esk8.de Kegel pulley, 15mm belt, 15/34 teeth pulleys
2x5S Turnigy Graphene 5000mAh
Benchwheel remote
3D printed enclosure, that’s actually surprisingly durable. (probably because I printed it T H I C C)
Custom griptape.
I’d probably regrip it (since it’s my own logo), and repaint the trucks if someone were to buy it.
Only difference from the build thread, is the 3D printed LED risers that I never finished, as well as the charging ports for my 10s charger. The LED strips have also been removed, since they were very bad quality… See below:
Yeah, I also personally think the charging solution will be a dealbreaker for many, but it was perfect for me and my setup
Thanks for your estimates! I’ll let it sink in for a bit, and see what I do then.
edit: Standard Caliber 50 clones regarding the wheelbase btw
Yeah, I know, just too lazy to research what the wheelbase is on standard Caliber trucks.
edit: oh shit you mean between the two trucks?
edit 2: I’m stupid, of course you do… wheelbase is 46 cm
too many paint fumes today…
why just 350 ? I think if you count every component he has used on his board, they are quite high tech
VESC… 70 - 80 eur.
Graphene batteries : At least 60 - 70 eur…
Mh what else… the board itself and wheel + pulley and motor system… that alone should be at least 150 eur for sure…
… on top of it all… the design itself… is worth something, check that enclosure… I cant confirm, but it does look almost psychotiller quality one… at least I think ive seen similar plastic ones made by him awhile ago…
