Hello guys, I’m on the market for a new soldering iron, currently when welding 14/12/10 awg wires
I have to use two soldering irons (30w+60w), not pratical
One thing that got my attention is a butane powered 3 in 1 kit, that serves to solder, heat gun and torch, anyone have one of these and can say if it has enough power to work on large wires?
At least 80 to 100 watts with a fat chisel tip. You need the mass of a large iron otherwise the solder will pull the heat out of the tip too quickly and you will end up with cold joints.
I’d reccomended just getting one of the cheap $30 soldering stations on eBay like the 937D. I have one and it has been working very well for about a year. You could also get a two in one soldering and hot air station cause a hot air gun is super useful as well.
I have one of Those butane solders… Not my first choice…
Something fast between 60-100w is the best. Lately I am using mostly the hakko iron that came along with my spot welder
You are maybe battling with wrong thing. 60W is perfectly capable of soldering AWG10 cable, and the tip doesn’t matter much.
What matters is the tin and soldering technique. Use Sn60/Pb40 rather than lead-free solder.
Then try to get the tip to touch as much of area you can, so the heat goes to right place. Sometimes you need to press the iron harder to the soldering joint to get desired effect. Also pre-tinning the tip helps to get the heat travel better.
FYI i have 80W Weller WS-81 soldering station, which gets the job done very fast, and my travel-iron is simple no name 40W, which also does it’s job with the method i explained.
I get by fine with a 3/8 inch tip @ 100 watts. AB has some nice pointed tips too but I haven tried them. A 80 watt iron from the hardware store can be had for $20. So you need to weigh how many hours the tool is going to used vs the cost. A $20 iron lasts me about a year of daily use. The AB tips are really nice and they are compatible with any iron with a gib screw type fastner/socket of the same diameter.
I use an off-brand 100W soldering gun, works really well on 10 gauge cable. I tried using a butane torch but I found it was too hard not to burn connectors.
