It works! Thanks guys
Great, really useful to change modes and current/watt control BLDC/FOC etc on the fly. Should be interesting if you are using to monitor all 3 slave vesc by canbus as well. Not sure if Ackmaniac has any custom settings in mind for AWD like he has for dual diagonal offset config. Anyway would be interested in swing your trip logs of 4wd posted. Would like to compare to 2wd at some point and see the differences lol.
I dont connect via can bus as Ive had too many issues with It. I have a separate BT module for each VESC for tuning and comparision purposes but just use one of the modules for efficiency testing and then multiply by 4.
Nice. Yes canbus canbe scary sometimes lol
Via the app you can also adjust a 4WD. You can define 2 controller idâs for the front axle. @BigBoyToys you can set number of motors in the app to 4. By this the values get multiplied automatically. Did you try already different settings for the front and rear axle? Like 30% acceleration power at the front and 70% on the back and at braking the other way round.
I have run different settings front and rear on my other 4wd boards but with the big grippy 107âs on the Carvon V3âs it doesnt seem to be needed. It doesnt have enough torque with the big wheels to break traction during hard acceleration or braking.
Im gonna be testing is some more tomorrow with the 83mm flywheels and will use the front rear power split you described if it starts breaking traction. I will be using it for sure on the 8085mm 4wd board Ill be finishing up in the next couple of weeks but again I dont use 4wd can bus anymore since its been problematic for me. I just run four separate bluetooth modules.
This is a truely amazing app. I couldnt get your donation link to work but I sent a token of appreciation to your email address via PayPal.
Thanks again
Fear turned into about 7 blown CAN transceivers. Zero since I abandoned CAN.
Do all the values displayed get multiplied? I felt like some werenât so if figured Id leave it set to one and multiply myself just to be sure until I asked.
I seem to have lots of freezing issues but its intermittent and unpredictable. When the app freezes its almost impossible to close and restart without waiting. Is there anything I can do to minimize this? I use a GALAXY S8 plus btw.
I think it doesnât only help when you loose traction. It also could help for stability. For example when you only power the front wheels then it is hard to make a corner. SO it should be helpful to have less power at the front to improve carving during acceleration. And at braking it also should be more stable when the front brakes more than the back.
And i am working on the crashes. But did not find the root cause yet.
Ill give the power split a try tomorrow and see if I can feels a difference in the way it handles.
I personally donât like traction control. With it off at least I know what itâs doing, that is, itâs still responding to the throttle in a predictable way to me. When TC is on and I hit a slick spot while accelerating resulting in a motor to spin up suddenly it feels like it pumps the brakes on the wheel with traction at worst and at least it stops behaving how Iâm expecting it to given the trigger position.
Hi, so, what do you mean with âblown CAN reansceiversâ, do you know more about it, or know anyone able to repair it ? how does a blown CAN Transceiver look like or can you/i acutally see it ?
I actually made a similar experience with my brand new Focboxes ? not many people seem to know about CAN troubles, or at least the only advice given to me is âuse a servo split cable its safer than CANâ on the other hand Trampa is strictly recommendin not to use servo split-cables with their new VESC6 I go with servo split right now, and its working great, still id like to know ,âŚis this a random bug, or a production fault,âŚorâŚ
if anyone knows more about it here i openen a topic with questions to it
http://www.electric-skateboard.builders/t/dual-vesc-can-problems/34035
Just released a new version of the app (1.62) which hopefully improves the stability of the app. Please let me know if it males a difference on your phone? Will take a couple of minutes for google to publish it so please be patient.
Installed, will test this evening and report back.
Thanks for your work
Every 300 miles I run on your app Iâm going to drop you a donation
Whatever you did drastically improved the stability on my phone. Im running a cloned version and the Original version on the phone at the same time and it hasnt frozen once even when both are connected and switching back and forth between the apps and when connecting and disconnecting. The app did stop once when switching from video back to the main screen but it restarted fine which wasnât the case before. It would hang up for over a minute and sometimes not eork again until I turned off the board. Quick work, nice improvement.
This thing is awesome, really liking now that I have an android phone that works for mode change. Taking a closer look, on the two android phones that still do not work (even with recent update v1.62), it is just the mode selection dropdown page that is the issue on some phones. Everything else works (including changing default and BLDC/FOC) but for some reason some phones are not able to pickup the selection of a new drive mode from that drop down screen and pass it along to the main app mode box. So it acts as if nothing was chosen so nothing changes. I know its not a priority, but would be great if that mode change drop down menu worked like the FOC/BLDC change menu, as the mode change feature is top of list for many people. I expect the different UI for mode change dropdown vs FOC/BLDC is driven by the fact that the menu options are dynamic and pulled from the modes setup section of the app (vs FOC/BLDC and default write to VESC are hardwired options). Even a command level prompt box where we type in a drive mode would help, not pretty but at least works. Just throwing that out there lol.
Interesting, so you are able to read data of both motors on two âclonedâ Ack-Apps ?. Are both apps able to connect to both bluetooth modules at the same time, and read and write data of both motors ? And sorry, im still a oldschool mobile user, but i got a android 4.4 Smarthpone gifted, so how do you clone apps ?
Do you have another Board where sou can try my or benjamins new firmware? If it works with this then I Know the reason.
Hi Nico, just i would like to know if is there a option to keep the track of the kilometers i do skating with your f+C++g awesome app, since i change very often the mobile phone i canât keep it, is a there a way to edit the km? thanks buddy, iâm in love with your brain.
