@TarzanHBK@rpn314 I suppose this one should work right? And four pins are enough?
I ordered a VESC from Alien and actually received it already. I was like ohhh wow a VESC for 100 Bucks. 1min later it was ordered. I just unpacked and started doing research on configuring the VESC and stuff and well here I am.
Just wanted to point out that you no longer need to do all this fancy stuff, because the new Vesc-tool can upload a bootloader to vescs that don’t already have one. I did this with my Maytech vesc and it went fine. Let me know if you need any help.
You need to upload the bootloader through command lines, not using VESC Tool.
Bootloader uploading through VESC Tool is only a trick Vedder coded in emergency to deal with VESCs with a FW but no bootloader (I mean, it has NEVER been uploaded).
If you try to upload it although one was already existing, you mess it up.
(See the warning of Vedder at the early stage of Beta for beta-testers : http://vesc-project.com/node/47 )
OK, Id really love some things confirmed if anyone can help:
I have a Vesc with 2.18 FW and its 4.12 HW
I have a Mac
I have an STLinkV2 ordered
I want to update the Firmware so I can use full features of the @rpasichnyk Metr App.
Do I need to download Ubuntu?
Do I need a PC emulator?
Or, can I just do the upgrade via VescTool on my Mac?
I’ve been reading and watching some vague vids for a few hours and there seems to be a few ways to do this and all of them are confusing for different reasons.
Theres talk of a Hex file. When I download from the link above, I get a folder with a few things in it. Will it all become apparent when I finally figure out how to run the STLink Utility?
If you have a VESC with a firmware already installed you can flash the bootloader from VescTool. If somehow you accidentally removed the firmware from the device you’ll need the STLink to recover it.
I had the misfortune to have used a bad USB cable and broke my firmware during a config upgrade on my FOCBOX.
In case that happens, you have to use the STLink tool to flash any firmware (I used 2.18 firmware file) back to the device.
I don’t have the instructions for that nearby, but if needed I can go look them up
TLDR; if there’s a firmware on there you can flash bootloader via VescTool.
Thanks Jamy! That sounds pretty simple then. SO the VESC TOOL will have the latest firmware automatically on it or do I need to direct it to somewhere?
I think it is. SO just to confirm… My Vesc absolutley does not currently have a Bootloader on it. So, with VESC TOOL, this doesnt matter? The tool puts a bootloader on it or acts as the boot loader?
It’s all back in my Raptor 2, but I got a picture here. I soldered to each of the pins above the cap (which was a pain in the ass because there was solder already in there…
The ground pin was the worst so I just connected elsewhere to ground.
