is the EN pin pulled up on the module? i’ve seen some that are actually pulled down, so you need to short the EN pin to VCC
No need. At least on mine, it works well without doing anything with (just a shrinktube on it )
So, once you have it connected and powered up is there anything you need to do in settings to make it work with the BLDC app?
Maybe check out the post 5 posts above yours.
Thanks! Misssd the ppm and uart part.
Anyone know of a DIY ble remote control
What app is everyone using for iOS?
metr and perimtr are you’re only really options (same guy, does different things). He requires that you buy his bluetooth module though. I think most of us on iOS just don’t, sadly.
@emmaanuel created one for iOS http://www.electric-skateboard.builders/t/new-ios-app-eskate-vesc-for-standard-and-ackmaniac-fw/32340
Thanks fantastic! I hadn’t seen that post yet, thanks for the heads up!
Thank you, reading i had to enable uart helped me. I had to set baud to 9600 too
Hi All,
I installed the HM-10 module and used it / got a read out on the app, now it’s stopped. Looking around the pins of the HM-10 + heat shrink I applied, there’s white clouding. I’m guessing that I’ve got the 5V to 3.3V issue.
Can anyone please explain what resistors are required and how/where to solder them in? (Complete beginner here to resistors etc)
Much appreciated!
Yep I did, but the posts that followed that said it was incorrect? (And I’m not sure what 1K ohm / 2K ohm resistors are to buy).
Can you reference the post? The resistors assembled in a T junction is a simple method of cutting down voltage which that guy didn’t seem to understand.
Resistance is the only main parameter that defines a resistor. Any new resistor with that resistance will do.
Reference post: http://www.electric-skateboard.builders/t/vesc-hm-10-bluetooth-wiring/12838/19?u=jalapeno_ninja
oh wait ur right. Didn’t see that coming. But I would highly doubt its the overvoltage causing the trouble. I had problems like that in the past and what I would do is restart my phone and it works again.
Check your wires, maybe you did not solder them very well and somehow something broke???
Hm10 modules usually work on 5v…
