@MontPierre did you not receive the motor pulley? I think the screws are M6. This is the item description
Package Included:
● 36 T Drive Wheel Pulley designed for Flywheel Style Longboard Wheels
● 15 T Motor Pulley with 8 mm bore for motor shaft and Four Set Screws for maximum security
● Retainer/washer for bolts
● 255 mm long belt HTD 5 M
● 265 mm long belt HTD 5 M
● x6 M6 Allen Head Screws
Sorry, I wasn’t been specific earlier. I have got everything as described apart of 265 belt missing( two 250 in the package). I’m just getting home and I’ll see if 250 belt is enough and then I can have my first ride on my board - super excited
Ugh. I definitely bought a set from someone using the same stock photos. Hopefully I receive the correct belt sizes. Are these pulleys metal & painted? Or are they printed?
Yeah unfortunately the whole set is totally unusable. My motor pulley won’t work as grub screws too big, holes don’t match up with abec core or the metal plate !! Just put a return claim on eBay for my pulley set. As a not as described claim, they will pay the postage to return (which they won’t as it’s to China) so eBay will step in and refund entire amount. So literally the whole set will be in the bin apart from 6 bolts
Yeah I’m getting new grub screw this one will tear my belt. Got Pulley to work with 4 bolts out of six haha. Rest wont fit unless I drill wheels. Waist of time, I got some money back off them but I will not recommend it haha
You still can buy directly from him.
Just wait for the chinese set and put a claim on ebay as “a not as described item” like @atenner said.
You will get your money back…
So, no go on stopping the shipment. The seller even tried to contact the Post Office. Too late. They were apologetic about the whole thing, so I like to assume people are honest. I’ll let it come in and see what happens. What were the ebay seller names where you all bought your knock-offs? Maybe my seller has a different batch. Though I doubt it. It does say in the description that parts may be off by 1-3mm. Silly me.
The belts are all 250mm. The motor pulleys only have 11 teeth. The grub screws are to small for the holes in the motor pulley (M2 i think).
On the plus side they gave me one extra screw for one of the wheel pulleys
Look as sh*it as mine haha. @atenner has received second batch from same seller with slightly better quality ( slightly more expensive ). Do your retainer holes match pulley holes? Mine are slightly off … At the moment I managed to screw in 4 out of 6 bolts because of misalignment. Done 7 miles on it - so far so good nothing came loose.
