Specs. Turns: 18T Voltage: 6~10S Lipoly RPM/V: 280kv Internal resistance: 0.031 Ohm Max Loading: 60A Max Power: 1510W Shaft Dia: 6.0mm Bolt holes: 25mm Bolt thread: M4 Weight: 369g Motor Plug: 4mm Bullet Connector Quantity : 2 $62 for both
62$ For both or 62$ each?
Uh oh… Not for me then
6mm shafts are alright. I have built several boards with 6mm shafts and they do just fine. I have snapped a couple after extended use with bent brackets and physical abuse but replacement shaft is only $5 and easy to do.
I was just saying that because I use 8mm bore motor pulleys but thanks for the info .
Infact where are these located? I might be interested in buying them as spares.
In Boston. I’m willing to ship them to you.
I’m having a problem finding 6mm bore 15mm wide 5mm pitch pulleys for the motor, preferably 16 teeth. Do you know where to find those fairly cheap? I have these same motors for a dual drive but I can’t for the life of me find the right pulleys.
Here you go https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F262632206462
Hi Malcolm, I would be interested in this deal, and I happen to live in Cambridge. Are these still for sale?
Uk or Usa cambridge?
Im in Eu and have same motor… can sell for 30usd + whatever the shipping cost might be
Never used, still sits in a box
Cambridge USA. I can give you $25 for it + shipping
