Guys sorry about noob question but I would highly appreciate if someone could enlighten me if it Is even possible to run two battery packs with two bms’s together in parallel?
BATTERY PACK nr1: 18650 12s1p battery pack + 60amp bms + battery status display + antispark switch + on/off button + charging socket. BATTERY PACK nr2: 18650 12s2p battery pack with 60amp bms and nothing else.
Can I connect these two batteries in parallel ?? Can I charge them both at the same time in parallel through the first battery pack ? How battery status would behave? Can it show battery status for both batteries ? or it is going to show status only for the first one ?
