These items should be in the drawer of any esk8 builder
I think someone else on the forum pointed these out but they are not too expensive and work really well.
https://smile.amazon.com/gp/product/B002AVVO7K/ref=oh_aui_detailpage_o03_s01?ie=UTF8&psc=1
Loads and loads of this stuff https://www.amazon.com/Gorilla-6035180-Tape-Black-Duct/dp/B000CSS8UE/ref=sr_1_1_sspa?s=hi&ie=UTF8&qid=1526789292&sr=1-1-spons&keywords=gorilla+tape&psc=1
What do you use the gorilla tape for? Would be better to use heatwrap for electrical wiring connections?
Everywhere.
On your sunglass lenses? :stuck_out_tongue:
How do you think people turn glasses into sunglasses? :roll_eyes:
I wanted to add this
Itā€™s a stained glass soldering Iron. I used to do stained glass and one day I was soldering 10 GA to my battery pack and just not getting enough heat to make a good joint, until the light came onā€¦
This iron works amazingly well for that purpose - delivers a whole lot of heat with high thermal mass.
Mine is a Weller W100P
You should add a high quality metric Allen key set, Or is it called a hex key set? I rounded my grub screw and key with a sh*t set :triumph:
https://www.amazon.com/Bondhus-12550-GorillaGrip-Fold-up-32-Inch/dp/B0006O4AEW/ref=sr_1_2?s=hi&ie=UTF8&qid=1526984285&sr=1-2&keywords=hex+key+set+metric
Donā€™t know if this is any good but the reviews look fine.
Hands-down the best hex keys Iā€™ve ever owned.
https://www.amazon.com/Wera-05073593001-Multicolor-Metric-Blacklaser/dp/B07BNJQ8XM
What did u use the 2mm bullet connectors for?
To connect the battery charger wires, itā€™s easier to remove the enclosure for inspections or repairs
Ah cool . I just use a jst. Iā€™m charging at 6 amps so still have a little head room.
Glad I found this. Starting to gather parts. Defently things I need on this list still. Thanks again
Been meaning to add to this. I end up using this in every build. https://www.amazon.com/Gardner-Bender-LTB-400-Electrical-Waterproof/dp/B000FPAN2K
I also found this to be useful however, it wonā€™t help if there is metal rubbing against it.
Is much better if you donā€™t use it at all and use heat shrink from the begining.
Heat shrink is preferable, but sometimes you canā€™t get the coverage you want or there is a sliver of metal exposed between the heat shrink and an xt-60 connector, thatā€™s when I use the liquid electrical tape.
T-Tool
Dual Lock (really really strong velcro)
https://www.amazon.de/Mini-Kabel-Stecker-Mini-USB-B-Stecker-Schwarz/dp/B001M1L1NQ/ref=sr_1_4?ie=UTF8&qid=1526076371&sr=8-4&keywords=mini+usb+kabel
https://www.amazon.de/Hankering-Heisskleber-Klebesticks-100mm-FĆ¼r-HeiƟklebe-Pistolen/dp/B074N8L7YP/ref=sr_1_4?ie=UTF8&qid=1525458325&sr=8-4&keywords=hot+glue
Organizer box
Battery holder for gluing batteries together
Has anybody managed to find a Uk/EU supplier for adhesive dielectric fish paper? Many thx
No. But why adhesive?
Iā€™m gonna wrap the parallel groups in it to prevent them from rubbing
