So, when are you gonna start selling these BALListic trucks to the rest of us? They look so stable and precise. I really enjoyed that last video. And trying to wrap my head around how these work in your various configurations is kind of a delicious, mental, mechanical pretzel.
Mmmm pretezels.
I have some design refinements happening for belt setups, Hubbs will be a piece of cakeā¦ CarVon setup isnāt gonna happen. When the belt drive thing gets done will post it up and put it out there. @psychotiller is the guinea pig on that prototype and will have Sixes hung on it if he can ever get me a set. He has these strange strict production stadards that doesnāt allow tears of child labor from forign countries touch his Sixes.
F#$k that boards fast
The Stooge for the W
Were you playing a bit there Bro? seemed like you used less throttle when you were in frontā¦ saving tires maybe?
Did I spot some family in there briefly?
Wife came along for the 32hr Colorado driveā¦ Someday would like to see a pro level talent on thisā¦
āIn order to finish first you must first finish.ā Rick Mears
@MoeStooge do you have a build log for how u built ur current board? I like the stabilizers and frame u have
http://www.electric-skateboard.builders/t/spur-gear-approach/24506. http://www.electric-skateboard.builders/t/nkp-3-link-evolution-thread/47413
Are you planning on selling your stuff soon?
I was going to ask the sameā¦ any plans for selling truck setups like yours?
A belt drive setup is in the works for the NKP. Got a few projects in front of setting up a production rigā¦ Dam day job gets in the way sometimes as well. Time will tell. If I make a few extra sets I will post it on the forumā¦
If you do decide to, please give me a heads up before hand and Iāll set the cash aside for when you do, I really do like your truck setup
The main Problem is that most eboard, using a vesc, could Output more power than it does! The vesc is so popular because it is costumizable and has a smooth acceleration/brake.
Well, if the People would decrease the pwm Limits they will gain a lot of power! go from 2 to 1.8 and feel the difference in acceleration!
Vesc is a great tool. I have a couple of FOC Boxes collecting dust for a cruiser project I would like to incorporate @hummies on my NKP 3-link. Would I use them for sustained 200a hill hammering at 30mph. I dont think it would last very long.
On my R2 i do not Need 200A. You mean uphill? I dont even Need 50A per VESC for 35mph.
Edit: your apporach is completly different. lower voltage, higher amperage, higher reduction. i just want to share the Information, that the algorithm of the vesc smoothes everything out thus it is not made for racing with the normal settings
Iām not sure the Raptor 2 can break 30 miles an hour on flat level ground, maby tweaked some. On this hill pull I hit just under a hundred amps peak on each ESC avg speed was 32mph 128deg F was the esc temp motors were cool to the touch at the top of the hill.
The vesc isnāt there yet. I hear claims of a super vesc in the works in the rumor mill. Iām hopeful of that. https://youtu.be/R0Y0-aL2cmU
