LOVE-IT! i have been thinking about trailers a lot lately… great not just for cargo, but small children! solar panels, big batteries etc…
Thanks onloop! Yep my thoughts have been on the same thing!
Well here it is, fresh out of the vacuum bag
It is far from perfect cosmetically, and now that I have done this a couple times would do it a lot differently…the biggest thing would be not being in such a rush to get it done!
Will have a bit of work in a couple areas, but considering this will have a layer of paint over it, think everything turned out well.
Threaded extension onto existing bolt, or weld in a new bolt extension? More info - how wide did you go?
Is your trailer going to be just the one truck at the back with wheels and front attached to your “hitch” or something mid-mount like a regular car trailer?
Yep, just threads on.
Wouldn’t suggest doing this to any truck that is being ridden normally though, cast trucks are notorious for bending as it is, and the added leverage will do it that much quicker, since this is only being used for a trailer there should be no problems. 180mm to 256mm
Am just doing one truck at the back wheels, wont ever being loading more than 60lbs so should be fine.
2nd coat of seal
And tomorrow it will be painted white.
Hey @onloop, hope your new larger space cell will be ready soon
Sample has been made… it will be waiting for me when I get home.
That deck is looking nice mate!.
Maybe need to make some carbon fiber truck brackets. Are the existing ones aluminium or steel?
Sweeeet!
Thanks dude!
My drop brackets are aluminum. If you built drop brackets out of carbon, would totally buy those up!
Ditto! I’d be all over a set of CF drop brackets…
@Wanderer - that looks really nice! A shame to cover it with paint… but just well done!!!
Small update, still not electric… but am slowly reinforcing the deck to make it stiff as possible. Ordered some 6K carbon twill, this stuff is incredibly thick compared to the unidirectional carbon I was using previous, pretty sure if I had of used this stuff off the bat this deck would be the desired stiffness. Oh well, live and learn. At least now I have a real nice enclosure area for the larger space cell that onloop will hopefully be selling soon.
@kai In order to make the “E-board Builds” category really easy to search & locate specific builds i am asking that you change your title to something descriptive that better expresses the makeup of your build.
Most of the new build threads tend to end up with a name such as "new- noob - noobie - beginner - first - build - help - newb" this becomes hard to keep track of.
I would like to see each build thread with a descriptive title, such as; Project Name | Deck Name | Trucks | Motor type | Mounting method | Voltage/Battery | ESC
Example The Samurai | Custom Deck | Paris Trucks | R-SPEC | Custom Mount | 10S | VESC
Sounds good…but how do I edit it?
Scroll to the top of the thread. There should be an edit button near the title.
Nothing there.
If you feel like editing it…
The Heavyweight | Custom Deck | Roja Hybrid Trucks | SK3 6374 149kv | Custom Hub Motors | 10S3P | VESC
Are you logged in? It wont work if you’re not.
How is he posting without being logged in? I smell black magic…lol
well, I just went to the oldest topic (that I created), and low and behold, it doesn’t have a pencil symbol…
Shazaaaam!! I’ve noticed missing buttons before too
