Got a plastic folder, the thick ones from the pharmacy, and use 3m 300l double side tape to seal it in place
How wide are your trucks and are they 12mm or the 9.52 axles. Been looking at all the cool stuff on trampas site but there is alot.
This are the trucks
http://www.trampaboards.com/mini-vertigo-street-carve-trucks--9525mm-hollow-steel-axles-p-12177.html
Do you mounts also work with the ultimate carve trucks?
The mounts work with all mini trucks
MBS or pneumatics?
MBS
I’ll give a run to the pneumatics she get warmer.
You got almost 20 miles with 2 6374 on 100mm wheels ?
How many watt/hr is yr battery ?
From 42v down to …?
How was that board on your feet after that trip.
12S4P of what looks like HG2 in his initial post for a total of 518Wh.
@Randyc1
-Just shy of 20 miles with the dual 6374 and MBS 100mm wheels.
-The watts/Hr just as @PXSS said.
-for the cutoff voltage is 30V.
@halifax21 The board flex is gentle on the feet.
What is your cutoff start and end voltage?
truly awesome built. how many teeth in the motor pulley and the wheel pulley?
Nice, I like that route…will have to do that ride together sometime!
@Kaly I was thinking about doing something similar with the urban carver as a hybrid “urban assault vehicle”, because I like the 7" pneumatics. Do you think the street carver would be a better platform to use? Also what are the motor mounts you are using?
The setup is 16T/40T on 100mm wheels
Did you cut those with a CNC or purchase them somewhere?
I like that point of view
The street Carver is a better option if you want to have the ability to swap urethane and pneumatics.
The urban carver hanger configuration is just 1.5-2 cm lower than the street carver hanger configuration. For the flexibility I can deal with that height difference.
