Only 30 amp cont rating for a 2p. I’m not guaranteeing you’ll have issues but you may. I have had problems in the past with 30amp discharge on a single drive 6374
Oh ok. I thought it would be more ideal, as its so thin and more like a nickel strip. I only got the idea from reading on the forum. Guess going with silicon wire is easier for me anyways Thanks @barajabali for the help
@barajabali is the expert when it comes to batteries, So take his advice.
And the 10s2p pack that I built with Basen cells was actually a disappointment for me. It had good range on flat ground at moderate speeds but when climbing hills, it had excessive voltage sag and it’s range was cut in half.
That is why I pulled it and replaced it with the Lipo build.
I agree on the 10s2p being a bit on the lite side… the board is not going to have much of a personality… but if you go that route the amperage requirements are much less. If we consider the 30Q batteries being 20A batteries (even through they are rated at 15A), you are only moving 40 amps. That puts you safely in the 10-12 gauge range. 8AWG wire is hard to work with in any form. I originally tried using 8AWG silicone wire for the short 1" connections between series, and failed miserably. It was also hard to keep 1" of silicone wire that was stripped of it’s insulation together during the soldering process. It’s basically 50 tiny strands not attached to each other. The braided wire holds together nicely in short sections.
The other problem was the wire would suck up all the solder and become hard, not allowing the battery to fold over. If you don’t need to fold the battery, it may work OK. It basically creates a solid solder bridge though. That’s why I ended up buying the 12awg flat braided wire after failing with the silicone wire.
I did use the 8awg silicone wire successfully on the battery to VESC connections without an issue. Since the wire was longer, it didn’t matter that it was sucking up some solder and the insulation held it together without issue.
You could probably use 12awg braid for all the series and parallel connections (instead of nickle strips), then use 10-12 awg silicone wire from the battery to the VESC.
