My charge module got super hot and basically fried when i accidentally reversed the polarity of the lipo
Did you remember to change the Rprog to a 5kOhm instead of the standard 1,2kOhm? The 1,2kOhms resistor set the max charge current of 1A, which is way too much. A resistor value of 5kOhm limits the current to 250mA.
@chinzw, I know that you use the proto M0. Would you mind making a diagram of how to wire the oled, micro switch, hall sensor, and nrf module for me please? I really donāt want to blow anything up lol!
I did not, i dont have these small resistors. But i may have made another wiring mistake which is only when chargingā¦
This would have caused the lipo to overheatā¦ Not the charger I think.
Soldered up a receiver boardā¦ Nice and neat
But I accidentally stripped one of the solder padsā¦ Sigh so had to jumper it via a wire insteadā¦ should still work I hopeā¦
Which BMS model is that? Do you recommend it? Iām in the market for a 60+ amp 12s BMS.
If anyone wants some high quality 3D prints I can do a small run of SLA āToughā resin on my Formlabs Form2.
I just printed some abec pulleys and they came out fantastic and dramatically stronger than the standard resins which are brittle.
The āToughā resin is apparently as strong as ABS.
Wow thatās awesome! Maybe you want to print the remote? Is just the last part what I need. Well and 3d printer also need
Iāve been getting a few PMās about prints. Iām based in London, UK but can ship globally for cheaply though my business (e-bikes for those interested). This resin is absurdly expensive compared to filament but I did some quick calculations and I can print a full remote for Ā£34 shipped to uk or 57usd shipped anywhere in the world.
PM me if you want one and Iāll send PayPal details. Iāve already done a few prints for other forum members.
Can I use this nrf module: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F222469277836
thats the one im using cause i had em laying around
Have u had any break ups or connection issues?
Because also that one isnāt pa lna
havent made the reciever yet, so i dont know yet. Still waiting for a connector cable.
How would I wire that module. I didnāt see any labels for the pins in any of the pictures on eBay
Great thanks!!
On the arduino that Iām getting it only has 2 3.3v outputs. I found a hall sensor that can work at 3v and so can the oled but I still need another rail for the nrf module. Can I solder the oled and sensor both to the same 3.3v rail?
