This is a good post to start. I intended on cutting holes into the enclosure and sealing it with rtv to make it watertight. Now I can see everyone’s great ideas.
I drilled holes in the back of my esc case and epoxied the female bullets into the holes. I think I stole this idea from someone though, maybe @scepterr?
Oh and don’t forget the hot glue or the stupid 4mm bullets will rattle themselves out
zero enclosure ports for motors. Charge port is the only port. Occasionally a pair of USB ports on my own builds. I used to make a flat cable for my sensor wires and run it under the flange but i have since started running 12 little wires under the 6 big ones in my wire channels.
For my Boosted clone build I epoxied some bullet connectors to the VESC enclosure. The connectors on the far sides are drilled through and will have the sensor wires extended through them. The sensor wires will be covered with red cable mesh to match the red bushings on the trucks. The black mesh seen will most likely be replaced as well.
Just curious if you get any interference with high amp draw boards. Maybe it is not noticeable since the sensors are neglected above certain RPM so no high frequency distortion occurs on startup.
