How are you going to mount the motors? I tried to use the gt mounts with 6355 motors but they are cut for a smaller motor…and not the same pattern…looks like you are just mocking up with 2 bolts…
I ended up modding some TB mounts to work…
Thanks @sl33py , I don’t mind the work. The heavy grit actually helps git rid of lumps and dips in between coats. It’s that last coat is have to make sure I use a higher grade sandpaper to get it nice and smooth. I might polish it one more time after I get all the electronics laid out.
I have this GoolRC ESC. @Cobber I’ll try it and see what I can get out of it. Not sure? If not I’ll try something else.
At this moment @Crushkrew, I have only two screws on each motor. I have to drill two extra holes on each mount to help secure them.
I wanna see this build with metro board red transparent 97mm flywheels. Even @longhairedboy would be scared in front of a build that red
Trying to see how I’m going to assemble electronics in the enclosure. Red transparent metro wheels would be nice. It would match the red transparent bushings on the trucks.
This is going to go really fast since it has so much red
Are you running those lipos in series or parallel because I tried to find the esc and I found one that is very similar and it says that it is 2s-7s. wouln’t 8s blow it?
@XvDarkVAngelvX Would you like to come live in my shop? I’ll feed you and take care of you and give you a place to worship Skatan as you see fit.
I think recruiting members for a cult is against the community guidelines
…then we need new guidelines.
@pat.speed, was going to hook up in parallel and see how well they run. Never used these esc’s before. Let me test first then I’ll try to go up. If I don’t blow these first. @longhairedboy, thanks guy. When I come down under. I might need a place to stay. I’ll take you up on your offer. I’ve seen pics of your workshop. I know I would have a blast. Lol
Cult! Thanks! i was wondering what this was called. Needed that info for my taxes. That reminds me i need more ritual gowns, i keep burning holes in them.
Sweet build dude! I have been thinking about doing a build with these evolve trucks myself, But i haven’t been able to find any measurements for them, How much distance is there between the motor mounts, what is the distance between the motor mounting holes, and how high are they from the ground?
At 16.7volts the display shows 100%, but at 15.7volts, the display still shows 100%. Something seems wrong there.
Yes I only just realise that when you pointed it out
Yes, the voltage meter wasn’t working right. I’m currently changing it. I’m going to make the enclosure longer and upgrade the ESC with dual Vesc.
Did you setup the voltmeter to your S count?
Yes I did. Something was wrong with that one. I replaced it. Now the new one works great.
