Hey there
I have put together a list of parts for my new board and need some help checking over it. For some reference, I am 170 pounds, I live in a relatively flat area but there are some hills. I don’t need it to go super fast. I am on a tight budget and any suggestions to lower prices are greatly appreciated. I don’t know too much about electronics so I could use some advice there.
diy-electric-skateboard-kits-parts/vesc-the-best-electric-skateboard-esc/
https://hobbyking.com/en_us/turnigy-aerodrive-sk3-5065-236kv-brushless-outrunner-motor.html
diy-electric-skateboard-kits-parts/torqueboards-2-4ghz-nano-remote-controller/
http://www.skatewarehouse.com/Bro_Style_Gold_Thumb_Griptape/descpage-BYGTGT.html
http://www.ebay.com/itm/Blank-Pro-90mm-Multiple-Color-Longboard-Flywheels-ABEC-7-Bearing-Spacers-
(2) https://hobbyking.com/en_us/zippy-flightmax-5000mah-3s1p-20c.html
http://www.enertionboards.com/electric-skateboard-parts/9mm-wide-drive-pulley-kit/
https://www.amazon.com/dp/B00J5J6B0U/ref=twister_B00J9MRX5K?_encoding=UTF8&psc=1
diy-electric-skateboard-kits-parts/4mm-hxt-series-connector/
diy-electric-skateboard-kits-parts/electric-skateboard-on-off-power-switch/
diy-electric-skateboard-kits-parts/single-bolt-on-motor-mount-only/
diy-electric-skateboard-kits-parts/male-male-servo-connector/
If there are any things you would swap out, could you please provide a link to that product.
If there is anything I don’t need, I am over budget and need to cut down a bit.
The one part I am stuck up on is the deck. I want to build my own, but I am worried that I might do a bad job and the deck will break destroying all the components. If you could give some advice on how to make one or what decks are good to buy. If I buy a deck I need it to be slighly compact to be able to fit in my locker.
Thanks for your help!
