@DeathCookies post 202. is right on this one. The cells do not lose longevity by being discharged near full capacity. The cells lose longevity by being charged near full capacity also the longer the cells remain near full capacity, the lower their lifespan. This is due to the chemistry of the cells. The chemical reaction while charging produces more oxides at high voltage state which reduce the amouny of charge a cell can hold. Over several cycles this adds up into reduced capacity, this is actually the reason why the more cycles your cells have, the lower the capacity. Even though the chemical reaction is mostly reversible, it is not 100% reversible.
So the longer your cells remain near 4.2V charging, the more you are harming them. That’s why spec sheets state that you need to have a timer to stop balancing after 2 hours in cv mode regardless of how closely your cells are balanced or how close to 4.2V your pack is.
@IDVert3X, post 203. the reason it is a good udea to keep them balanced is so you can get the most capacity out of the pack. Nothing to do with health. If your BMS detects any cell at 2.5V it will shut down regardless of other cells being at 2.8V. By keeping them balanced, you assure that the voltage difference between them remains as low as possible and you are not wasting any energy.
On non-BMS setups, only the total voltage of the pck is read, so in this case it is important to keep them balanced as when your ESC sees 10V on a 4s pack, it means that each cell is at 2.5V or nearly there. If unbalanced, you could have drained a cell beyond 2.5V and reduced its longevity. Again soec sheets usually state what is the minimum voltage on the cell where you should not try to recharge the cell (usually under 2V for 18650 cells)
@Okami, post 204, balancing if not done right is harmful. Read above.
@SORRENTINO, post 206,208-209, you are exaggerating. He is talking about a 0.05V difference. If he has a dead cell and properly adjusted his voltage cutoffs, this system is completely safe, his cells will charge faster and his cells will last longer.
If a cell has higher Ir and does charge faster, they will be out of balance by a proportional amount. If they are not that far off, then the Ir is not that far different. V=I*R. Simple as that. A cell that is going bad will get balanced whenever it needs to be balanced. Again as long as your low voltage cutoff is reasonable, no risk and dare I say his bad cell will last longer than if it were being balanced every cycle as it would spend less time near full capacity.
@DeathCookies, post 210, the cells are usually rated for ~300 cycles above 70-80% original capacity not 1000. Look up the spec sheet of the particular cell you use.
@IDVert3X, post 211, you’ll have to explain why, because that is wrong unless you are using the cells to their full range of 4.2V-2.5V without a BMS.
@Okami. Post 212. Why is it overdoing it when it’s such a simple change that will make his batteries healthier?
