http://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/982?u=maxid Selfmade idler pulley with a small 3D printed spacer on a @ProtoBoards mount
We don’t currently plan to re-stock 90mm wheels anytime soon. Because of their weight they would cost around £20 to get shipped to Cali. @Maxid The idler looks great! I have thought about implementing one in the past and now that I have seen it done I may start having them manufactured in the future. Have you tested it yet? If so does it work well and is it reliable?
Not tested yet - just had it rotate on the bench. have to think about the enclosure now for the new build before putting it all together.
any preview for vesc on stock?
Any news about when the motor mounts will be back in stock?
Depends on your charger - the plug itself does not have a polarity. It think people usually go for gnd on the outside and pos on the inside. You need a multimeter
To be exact, which one is to the outer side and which one is to the inner pin?
You can test this with your multimeter
Hi sorry to be a blag but would like to give u money at some point do u know when ur likely to get stock in cheers
I’m interested by the motor mount. Is it available ?
I second this…
Does anyone know if @ProtoBoards is still actively selling stuff? The mounts seem to be sold out for quite some time now and the account was last seen on this forum in march. The mounts were awesome so it would be really sad to see them go.
Hi, we are still activley selling products. Recently I have had little time to update/work on the website causing the lack of updates. Now that I have time to start working on Proto-Boards again expect to see many more updates in the future. Best Regards, Luke
hey do you guys have any 16t 12mm motor pulley
