ok guys I’ve come to a crossroads I want to keep the fl(s)exy Fattail but all the negative hype around flexy eboards has me questioning it more than ever.
So my current thoughts are:
-Keep Fattail, just build it and if its not working out just swap to different deck. I kind of like this idea as I was always planning on building something that could be swapped to another deck “easily”
For reference I have a boosted Dual+ with a modded drive gears and 97mm’s to hit 25+ and love the feel of it. However, this board will be a little faster at 29+ mph
I have heard a lot of good things about the highground and I do like the asymmetricalness of it. I ride in NYC though how do you find it handles rougher pavement? I would still run the 107mm F1’s so that would probably soak up alot of it?
I’d probably run a 1/2’’ shock pad too if I went the stiff downhill board route
Im my experience it’s not really the deck itself that mitigates the vibrations of rough pavement so much, but rather the wheels, shock pads and bushings. Don’t get me wrong, you will feel more vibration through a 10 ply rigid deck than 7 ply flex deck, but most 9 ply decks are pretty close.
I have some pretty rough pavement were I skate too, although not as bad as yours. I mostly run either @psychotiller 6 shooters (numies) or 90mm 75a Abec 11 Flywheels. Both doa good job. The Flywheels are better, in my opinion, with a rubber shock pads.
I think you will be happy with it. My only issue is the lack of cutouts, the Vugenhausen are little deeper making for less possibility of wheel bite, but its enough.
My only issue with the highground is the concave is pretty deep so my front foot would feel like my toes were being folded back onto my the top of my foot…if that makes any sense
I run a 12s4p 30q cells with Dual 6374 107mm wheels and 16/36 gear ratio and I top out at 41mph with these gears and get 18-20 mile range riding hard most of the ride if I go easy I’ve gotten 30mile range and I’m a heavy guy. So I think you are under estimating your planned set up.
my gearing is gong to be 16/44 and at 85% efficiency I would get around 29mph. But your are right about my range, sounds like I’ll get way more than 12-15 (which isn’t a bad thing ha!)
The new deck came in. So far I do like it, little worried about whet bite, already wana cut it or something. Also got the drive and wheel pulleys in, BKB pulleys are choice. Motors should be here within a week, cells show up Monday, FOCBOXs are probably less than 2 weeks away, and to try and combat the terrors of wheel bite a 1/2” rubber riser. Need to buy BMS, on/off switch, and decide if I’m spot welding this battery together or if I’m outsourcing. Also need to figure out the exact belt to run the htd325’s didn’t fit. Bought some htd375’s hope they workout.
Where does everyone get this belts from? I found one site with a slew of 5m belts but their shipping is always $25 no matter how many you buy!
To do so I needed to put 5 speed washers on the inside of each of the rear truck. So the question is, am I going to die because of that? I needed to for clearance reasons, the motors would touch if I didn’t. Pics of effects of 5 washers on the inside:
All my tight clearance woes could be fixed with thinner mounts or wider trucks. I’d prefer wider trucks but the only trucks I could find wider than my 10” caliber II’s were those wide ass trampa trucks but I don’t think they’d work out for this as I think they work best with the trampa upturned front and rear mounting points.
So to recap I’m hoping everyone could give me feedback on if I’m dumb for the 5 speed washer thing. If so what motor mounts or trucks should I get to fix it? Also where do you guys buy motor keys? The maytech motors didn’t come with any…
Other notes: I’ve got the Samsung cells, mini controller, and dual focbox mount. The focboxs are currently in transit, as are some longer belts to go with the idler set up.
Need to buy:
BMS, charger, fuses, motor keys, power button and battery indicator.
It doesn’t look like the threads are making it to the nylon inside the nut. If not then that will come off with vibrations, either get slim nylon lock nuts or flip that nut around so it goes through the nylon first.
I still have one speed washer between the nut and bearing on the outside of the wheel. I 100% need that right? If it went straight bearing to nut that’d get me more treads but probably not the best for the life of the bearing.
