Idk i just wired it right (as long as i know )connected it but noled light and no led on the reciever and no working Motor
I mean, a spark at the plug when it gets connected, If you saw a spark inside the VESC its no good news. I read some units had problems with the pin connectors punching through the main wires insulation. Does anything look cooked on the board? Maybe some pics will help
Ill get pics tomorrow and ill try to connect another time…
Can you post some picture ?
Tomorrow i will
Are you still using the same battery setup?http://www.electric-skateboard.builders/t/did-i-do-sth-wrong/8812
Since it produced already a spark in your old configuration it might be still causing problems.
Normally yes bit i forgot connecting
Wrong alarm was only sticky crap
I cleaned it and there is nothing wrong with it…
Is there a test if it is still alive without lipo?
You could use a 12V power supply.
I’d recommend d re-soldering your red cable to your vesc’s main board, that join is really bad! 3rd to last picture
Post a pick of the connectors so we can see if the are reversed
Man, this looks really bad… you should try to stick with black for negative and red for positive… I can’t even tell IF you have something reversed on that harness because of the color mess.
Who produced this VESC? No offense, but those joints are all really bad looking IMO… High heat, thick lead solder, and less than 2 seconds to touch and you should have beautiful joint. This looks like the soldering I did when I didn’t know how to solder correctly.
You can clearly see that the wire wasn’t even tinned lol
That’s the first time I see such a solder joint on one of our VESCs.
Strange thing, but please PM me and we get that joint right and check, if it was causing that spark, which I doubt, since the battery looks a little bit strange too.
it isnt from you @elkick sorry for the missunderstanding… I just thought you would know the problem… Idk where i bought it from im gonna research it.
