wow ! what filament did ya use - thanks for crediting (it’s okp here!)
This is going to be a sick build. Really like that deck!
Protopasta glitter flake - figured the Sparkle could use some sparkle…
Its a little brittle tho…printing a couple in ABS now…will post pix…
I am also doing a build with one of the redemberboards.com decks (thanks @treenutter) and @psychotiller 6in AT wheels & RIPBA mounts. I am using Paris 195’s instead. with I almost posted a pic of parts today, but figure I’ll wait until I actually get all my parts in. Good luck, I look forward to seeing how it performs and looks.
@Crushkrew Looks like you will get to the finish line before I even start the race…That will be one of the baddest boards to hit FLL streets!
Watch out Riverwalk!
It will be fun to test out our boards, they are same but different as wise chinese man once say…
No doubt
Thanks @Crushkrew @lox897 @mmaner @Titoxd10001 ! Yes, I’ve been exposed! I won’t hijack @Crushkrew’s thread; will share the news in a separate thread later on. TLDR: I’m now hand-making and selling decks for esk8. on IG redemberboards
Yea the sparkle filament is cool but too brittle for the thin wall sections…think I’m going with a Ying yang deal…blk abs and wht petg…
Tell me more about those Maytechs 63s, I found them recently and just cannot find anything better. It’s all gut feeling though and price is rather steep to just try them.
What size belts and motor pulleys are you using?
12mm…16/60…you?
Same. What length belt? My 340mm are to tight and the 345mm are too loose. I’m missing something, just haven’t figured it out yet .
340mm…seems about right but I only have it mocked up with a couple screws…need to pick up some more…I’ll let you know now…
Got my Redember Board today…it’s sweeeetttt…
Couldn’t resist a couple mock up shots…
Now gotta take her apart and start really building…
Not sure about forward mounted motors…tboughts?
Nevermind…decided to run rear mount…
@Crushkrew @mmaner 340 belts.
You just need to loosen the motor bolts enough to be able to slide the motor while putting the wheel and belt on. Then pull the motor away from the wheel pulley until the belt is tight and tighten the front motor mount screw. Then take the wheel off, tighten the rest of the motor screws and then put the wheel and belt back on. You shouldn’t have to readjust the belt tension again after that first time if you get it right…
You may want to remove the outside flange on the motor pulley too. It makes more room and makes for faster wheel/belt maintenance.
