so you recommend me just to let the bms out?
No you can use BMS, but you need to buy 6S LIPO BMS, not 24S LiFePO4ā¦you look like you dont know anything about itā¦
Read this This also might help
ANd just few random links from google, some of them might be usefull Some might not, I did not read them, just linked those who look interestingā¦ 1 2 3 4 5
Just read and read, it is not easy to build your skateboard, its not just about getting an answer, it is also about understanding the problemā¦
6s 2p u might need to pull more amps than esc can take and over temp shut down. U donāt need a bms. Especially w lipo its easy to attach a lipo discharge balancer and be careful
Read your links and i think i got a good one now
http://www.bestechpower.com/communicationbms/BMSD328.html
but if i want to upgrade to a dual motor in the future do i make the motor and the vesc parallel to the other vesc and motor becuase if thats how you make a 2 motor system i need to get this one another question that is like never talked about what does the overcharge voltage mean? If i use 3.7v batteries x 8 wont the bms work then? Hope you guys can help me out with that
This one would work, but i dont get why you prefer these modular BMSes, they will be way more expensive than normal 8s BMSā¦
Overcharge voltage protectionā¦SEARCH BUTTON PLSā¦when you are charging your batteries it stops the charge at 4.2 V (or a little bit less), the same thing happends when you are going town the hill with fully charged battery = NO BRAKESā¦
But you just linked me that this was a good site to buy a bms?
what happens if you have overvoltage protection on your bms? Iām guessing if you have it it will stop further charging of the cells when youre braking. so then what happens? the vesc isnāt going to shut down and the energy has to go somewhere when being directed somewhere other than the cell. I guess something blows up while you lose your brakes?
Yep, exactly More detailed answer
@epster Yep, it is good site, I just think you dont know what BMS is for and what you can expect from itā¦
Hey guys do you have a good recommendation for a VESC because i think it would be smart to make full use of the motor by changing to a 80A vesc
if i go with a new vesc 80A i will go with this BMS for my batteries
http://bestechpower.com/296v8spcmbmspcbforli-ionli-polymerbatterypack/PCM-D131.html
or this one depending on the vesc
http://bestechpower.com/296v8spcmbmspcbforli-ionli-polymerbatterypack/BMS-D298V1.html
