I’m planning to build my own battery pack for my board… I’ve done my research on how to build them etc but one thing I still can’t understand is choosing the copper wire size for soldering… I don’t have spot welder so soldering is my only option for now… From what I understand, copper wire can deliver higher current compare to nickel strip… Btw, My configuration is 10s3p and I will be using dual Alien 190kv 6355…
The bms I will be using is 60A for continuous discharge, 120A peak discharge…
Now the question is, what gauge copper wire I should use in order to deliver max 60A to the VESC (30A for each VESC = 30A for each motor) without causing too much heat on the wire or worse case break the wire connection…? I read a few post saying 14 AWG is enough but I’m not really sure… A lot people use only 2-3 layer nickel strip which can deliver less current compare to copper wire, but have no problem at all…
Anyway I arrage the battery this way so it’s relatively thin, not so wide, but long configuration…
Im am building the exact same setup just with 5 pr cell, still 10S.
And i use the 0.15mm nickel band plus 1.5mm solid copper wire. If you are only going to use copper wire and 10S. Then go with 2mm just to be sure.
I think you can make it with all down to 1mm since the max current draw pr cell is 60/10 = 6A. which is not alot. But rather be on the safe side with a bit thicker wire.
That’s where my calculation went wrong… I thought I have to divide the max current to how many cells in parallel which in my case 3p… So i thought each cell will have to deliver 20A…
So based on this diagram having 10-14 gauge wire for the battery connection is alright for my build right…? Since 14 gauge wire can allow up to 24A current while 10 gauge wire can go up to 52A… I think I would use 12 gauge wire between the cells and 10 gauge for the positive and negative end…
Hey. I’m following your diagram to build the same battery since the configuration is the best for soldering solid copper. ( I know soldering isn’t the best way), sorry if I’m being stupid but do you need to insulate between the two rows of 15 when pushing together or can the whole thing be pushed together then shrink wrapped. Cheers guys!!
You need to insulate the gap… The only thing connected the top pack and bottom pack is the number 5, connected with the wire… I would suggest to insulate and get some thin foam (I use heat resistance one) in between… There are other configuration that don’t require these… But the negative wire will be on the bottom right instead of bottom left… Your choice…
@BladeZ Not exactly sure what you’re going to use that copper wire for, but generally we use shielded (silicone) wire unless you’re making short connections and they will be wrapped in another way. I can’t read the description but look around for battery builds here and you’ll find lots of examples and part lists.
