Gear ratio was too tall for a single 5065, need a dual setup or a bigger motor if you want to run tall gear ratios.
Did some of the enamel coating on the copper wire melt due to the heat?
As soon as it arrives I will pull it apart and check it out!
Just installed the new parts! http://www.electric-skateboard.builders/t/build-log-waterproof-longboard-10s-life-with-vesc/7157/97
