I Just had a few sets made and will get them in on Tuesday. I will weigh them and check with a few shipping companies. Do you need 1 or two.
only need the one set, a mount and clamp that is.
Can you give me an address or zip code.
Sent you a message
Looks like shipping is about 25.00 thru USPS
so is that about $70 for the mount with postage?
Yes, the mounts mounts I ordered should be here on Tuesday. Unfortunately I can’t ship out till next Monday. Let me know if you want to try this. If it ends up costing more I wil let you know and you can make the decision.
Thanks
Yeah, I’m pretty interested at getting one and it’s still cheaper from you than anywhere else, could you just confirm the CTC distance on the 63 mount plate?.
I’ve been reading into it a little as well, is there a way you could say the value of the parcel for shipping is less than £15 for my end, cause that way import tax can be avoided, which would be one less cost to worry about.
C to C is 60.5mm to 73.2mm. No problem declaring less than 15.
Thanks
Korry
Oh wow, I’m like right next to you Whats the max C distance on your mounts? I’m finding my 63mm motors hit the trucks in reverse mounting even with 74mm c distance.
The max is 73.2mm for the mounts coming in today or tomorrow. If you want one with a larger C to C let me know what you need and I can have one made up. If I can get the order in today I can have it by Monday or Tuesday to send out to you. If I don’t get it in today then I wont be able to order till Monday, then another week to have it made and shipped to me.
Sweet dude, if you drop me a message with your paypal or something so I can send you the money over, just figure out the price and let me know.
@TheLastEnting, Just got the mount all packed up and ready, it was cheaper than I thought to ship it to you - only 13.50 USD. so 50.00 for the 63xx hole pattern mount and 13.50 for shipping = 63.50 USD.
My PayPal is [email protected] - please let me know when you send payment and I can see if I can get it out today.
are those parallel motor mounts? quad motor dual drive?
looks like your way of ahead of me
Thanks,
USPS tracking 9475703699300196360362
Turns out that is not your tracking number it is the scan number. I was told your tracking is LZ967662345US and should be there by the 28th.
No, but the thought did cross my mind. I wonder if you could run two parallel motors on one esc? Hmmm. Tank tracks come to mind again.
@korryh made me these extra long mounts for my unconventional mountain board build, and was kind enough to add a second set of mounting holes at a standard center to center distance. That way when my project fails or I change my mind, I could use these on another board with regular size wheels, pulleys & belts.
Oooh, I like the track idea - stand up snowmobile. Would need water proof components. Maybe tracks on front and back.
@korryh Wow here by the 28th, a lot faster than what I waiter for my space cell from enertion and about the same distance at that.
