While the USB programming card is like $20 shipped (which makes it even closer to the price of a VESC) it makes a big difference. It also let me flash some custom firmware from FVT that someone somehow somewhere got from a guy working at FVT that is made for electric longboards. The acceleration curves are MUCH better than the stock ones.
Do you have a copy of this firmware any an info about flashing the fvt using this? I love everything about the fvt’s except those curves are not the best… This firmware sounds like a game changer…
Any info and/or firmware files would be much appreciated by the community
It’s pretty straightforward flashing it once you have the USB card. Just connect the ESC to the programmer and then the programmer to the USB. Then install the software that lets you edit the parameters of the ESC on FVT’s website. These options are nice for tweaking the breaks, and motor timing, but the acceleration way to harsh even on the lowest setting. Once it detects the ESC just select update firmware and select the hgm file of the new firmware. The only downside is once you program it with that firmware you can’t change any of the settings, but I like the way the settings are anyway.
USB Link software
Custom “Longboard” version of firmware https://endless-sphere.com/forums/download/file.php?id=179865&sid=367ac6789c8ef5fc0377eec669c1ace0
I got the HK 120A car esc. I use it with a 6s 8000 mah battery and have had no issues.
I do live in the Netherlands and ride pretty much on flat ground most of the time though. At less than 35 euros, I’m quite happy with it.
@jakobnator I am almost 100% sure this is the correct link but just to be sure, I have the FVT 120a,… Is this the correct link? http://www.rcjuice.com/usb-programming-link-for-fvt-esc-s.html
Best Regards, JLabs
Yes, that is the correct one I bought it from the same website too.
If you have the programming card you don’t need that. You can connect the programming card to the computer thru usb
Check this out looks like torqueboards but am not sure either way its a decent price
That is for multi-copter. I don’t think it has brake.
TorqueBoards uses those ESCs except he uploads custom SimonK firmware on them.
Sorry didn’t know, thanks! You just saved me $20!
Wait, so we can just upload SimonK firmware to the esc, and it will have brake function?
Only certain people have access to the firmware. He is one of them.
I see, I thought it was widely available firmware. I remember hearing about it on endlessphere. Also, I have found a cheaper version of that esc at 70a: http://www.aliexpress.com/item/New-Favourite-Eagle-80A-HV-OPTO-5-12S-LiPo-Battery-High-Voltage-Airplane-Brushless-ESC-with/32486227618.html
Couple things…
- you will also need a UBEC for your controller
- Keep looking you can find these even cheaper
- requires a bit of hacking to work
Do u mean uploading the code is not fool proof? Also why would I need a ubec? I have battery power
This is a High Voltage ESC- i.e. up to 12s- i.e. 3.6 Volts per cell (lithium battery nominal votage) x #of cells (eg: 12) = 43.2 V which is quite a bit of voltage…RC recievers like those used here - gt2b, mini, badwolfs, flysky ect. have a recomended voltage of 4.8 - 6.0 Volts. UBEC ( a trademark brand ) Universal Battery Eliminator Circuits drop the voltage down to useable levels for servos or RC recievers.
Uploading firmware to HV ESC is not plug and play simple. First youd need the specific software ( not many have it) and then you’d need to load it and reflash the ESC - which is not just a simple usb pluging and download.
I’m not trying to disparage you from working this problem - totally you should go for it, but read some more and you’d learn this yourself. Part of DIY trade touted here is figuring things out. Google is your friend
Ok, I thought that you thought that I needed a UBEC to flash the esc… I havnt seen UBEC used in any builds I have come across… I will look more into it, may I havnt been looking for it. Have you flashed the FVT 120a 6s esc with the new firmware?
Thanks!
i think @monkey32 is referring to the 12s one, not the one that you have @JLabs. i have the same one you have and i have flashed it with the Eskate firmware which makes it a lot smoother, but for some reason when i brake all the way, the esc stops responding and have to turn it off and then back on for it to respond again. but if i brake slowly then it’s ok, which is better for the belt anyway.
Ok, that’s what I thought… @monkey32 made the flashing sound complicated… Is it? Any tips you can give me?
