You are being contrary. I understand what you’re saying about airbags, abs, etc. but those are all part of mitigating risk. Yeah - start the discussion. But it’s not likely a VESC issue here - most likely the Tx/Rx. Why i use a GT2b - less prone to these issues.
I disagree that certain ESC’s are safer than others. A properly setup ESC (or VESC) with a reliable Tx/Rx setup is just as safe as a similarly setup ESC. Now, before you jump on that - this also equals same setups for brakes, acceleration, etc. Some ESC’s have limited control of those settings. But once configured safely, for your skill (some like more acceleration, some like more braking force) - it again is up to the rider to choose how to operate it as safely as possible.
And gear was already mentioned - nowhere did i suggest to not wear gear. Quite the opposite.
@CSN - i think the wheel lockup is related to the Tx/Rx, not ESC. Folks with this issue should comment with what they are using to confirm. The timeout issue is definitely concerning - but a fair point to consider is does a normal hobby RC ESC also have this timeout?
