We have a lot of info in different threads about different 18650 batteries and i´d like to start a thread where you can talk about why you choose exactly that specific cell and help others decide which cells to use.
LG HE2 2500mAh - 20A
LG HE4 2500mAh - 20A
LG HG2 3000mAh - 20A
SAMSUNG 30q 3000mah - 15A
SAMSUNG 25R 2500mAh - 20A
Sony VTC5 2600mAh - 30A
Sony VTC6 3000mAh - 30A
I think these are the common ones. For example @chaka is using HE4 i think?! And esk8.de@elkick wants to switch to VTC5 in the future because of better lifecycles?!
So throw your batterys in here and let us know why you choose or will choose it
They were easy to access via a group buy and spares are readily available on Amazon. Many forum members have used them so there was some additional assurance that they were useful in esk8 applications. Sometimes the voltage on arrival varies, but it’s always between 3.5V-3.7V and I’ve never received a “dud cell.”
“Sony does not want consumers using their cells. It doesn’t make any sense that Sony would just abruptly exit a lucrative business making 18650 cells for industrial use. Their cells were never meant to be used directly by the end consumer and for this reason they have drastically cut the number of companies/manufacturers they sell to and therefore currently only sell to very large manufacturers of battery packs (laptops, drills, power banks, OEM use, etc). Because of this, there are fewer and fewer suppliers/distributors who can get their hands on the legitimate Sony cells and sell them abroad.”
I drew the board’s two pieces in 2D CAD and then figured out the size of the recesses by measuring the cells and electronics with a caliper. I then had them CNC routed and milled by a local company with me providing the 15 mm birch plywood for material.
The board does have a little bit of flex, but with me at 80 kg and with my wide stance and feet near the trucks it doesn’t pose a problem. I did however take a note of the flex when my taller and heavier friend got on it, with his feet closer to the center how much the flex was due to his larger weight and narrower stance.
I’m planning to adjust the geometry of the pieces a little bit to provide a bit more support and lessen the flex.
Ive been hearing great things about the VTC 5A, from what i understand Sony took the VTC5 and tweaked the chemistry so they perform better in cordless vacuums. I would love to try a pack of these but there a little too expensive for me.
Vtc6 batteries do not deliver the rated performance. Actually they are not even better than HG2 cells. So no need to pay the higher price just for the sony name.
Edit: i posted a discharge curve some time ago when they were brand new and I wanted to show them to @whitepony
E:upped fixed images.
As you can see, VTC6 have not only more Ah, but also less voltage sag, which turns into a nice gain in energy.
E2: @5A its roughly a gain of 0.8Wh/cell or 8.5% and it only gets better as your power draw gets higher.
