The Carvon V4 Speed drives are back LVE on the Website for $599 January 2018 delivery.
Finally you can build your own EVO or 4x4 your way!
https://www.carvonskates.com/store/p45/CARVON_V4_SpeedDrive.html
Features and Tech Specs:
Dual 110kv sensored motors, 2500W each Custom-made precision CNC hanger and motor mounts Motor mounts are screwed on for absolute no stator movement Stepped-down axle (from 12mm, 10mm to 8mm) is removable and replaceable Motors can be easily removed and inside bearings replaced Low-carbon flux steel tubes for more power and protection Axle end-to-end is 11 inches (280mm)
Recommended Use: Optimal rider weight is 200 lbs (90 kg) or less for 2WD builds, 275 lbs (125 kg) or less for 4WD builds. Not recommended for very hilly areas. Use 97mm wheels for street riding, 90mm (minimum size) for track or smooth and clean roads. MBS All-Terrain 100mm longboard wheels can be used, but do not ride off-road or on grass. Best used with a drop-down deck and with an enclosure to make sure the motors are shielded from most road hazards. Use a 12s (preferred Samsung 30Q) battery pack with minimum 3p for 2WD, and minimum of 5p for 4WD. Use only Vedder’s ESCs. Sensored BLDC mode has higher top speed, sensored FOC mode is near-silent. Do not misuse, abuse, overuse or neglect. Do not do tricks. Do not ride on rain or soaked streets. Rider must be at least 16 years old and responsible. Always wear a helmet and safety gears. Obey traffic, local and community rules. Be respectful to pedestrians. Be a good ambassador.
Does not come with front truck or wheels. Ships Jan 2018. For more info on how to setup your V4SD, check out this thread
