Hi, simple question here, does this wiring diagram look right? I know next to nothing about BMS’s so I need some input. I would like to bypass it and use it only for charging and I don’t think my diagram bypasses so i would like some input on this as well.
If I did it like this, do you think I would be fine with a 60a BMS? I am using an 8s 5000mah 20c LiPo battery setup with Ollin VESC, and @Jlabs 6354 190kv motor.
I think you will be fine if you discharge through a 60a bms. If your running a single drive, you can set your vesc battery max at 60a and the bms and battery should handle it no problem.
A 60a Battery Supports bms is rated for 60a continuous current.
And if you set your vesc battery max at 60a, you theoretically should only pull that much at full throttle.
And, discharging through the bms gets you all of the protective features the bms has to offer.
And since your bms does not have a dedicated charge connection for the negative charger wire, Use the P- connection for the negative charge wire
And in case you didn’t know it, Battery Supports and Supower are the same.
So my batt max is only set at 30A right now though I might want to increase that in the future, I would definitely be fine with a 60A BMS right? And would my diagram would for that 60A BMS?
You should be able to increase your battery max to 60a no problem.
As far as your diagram, I can only assume that it is correct because displaying the xt90 connectors as you did, obscures the actual wiring path.
I would need to see your diagram without the connectors in order to say for certain that it is correct.
I need to see the wiring path, How you connect the wires is irrelevant.
Example:
Here is a version of your diagram wired to bypass the bms during discharge.
(I made this before I found out that you where using a bms that you could discharge through)
