Thank you whitepony, it means a lot to me.
Yes, But hand layup also can achieve the similar result.
It would be cool if you coild incorporate a remote into these gloves and the face mask onto a helmet.
Avengers Hulk Buster Mask and Fists Battle Gear Bundle
https://www.amazon.com/dp/B01ITPR6XQ/ref=cm_sw_r_apa_TFwfybSRPQ9BR
Or just rock the whole helmet. Marvel Legends Iron Man Electronic Helmet
https://www.amazon.com/dp/B01B4NLOW4/ref=cm_sw_r_apa_AMwfyb1WF6B09
That could have been an awesome Halloween Costume with this! Unfortunately, I haven’t put it together yet. What a shame!
Beautiful fit and finish!! WOWZERS!!
Update. Finally, I have a chance to put it together with 10s5p battery pack. The flex is perfect for my weight as I planned.
The flex test with the split enclosure.
I
https://www.youtube.com/watch?v=ZYdafNlwFjw&feature=youtu.be
awesome. this is art.
Wow this is so epic!! I just wonder how you could fix 50 cells in that???
that flex looks really perfect!
Looks fantastic, great job!
Great quality build with a great quality 3D printed pulley That flex is amazing though. Definitely going to try to go for something like this on my next board. Good job man!
Yeah, Your pulley design is awesome!
This is so well made and polished. Hope I can somehow become half as good at working with carbon fiber as you.
Thanks. I am sure you can. There are lots of threads that explain how to apply carbon fiber to your deck on this forum, it’s quite easy.
I am planning to do laminating CF on a wood deck soon without using a vacuum pump.
Why? You are obviously ridiculously skilled and have the tools - why wouldn’t you use vacuum when laminating CF to wood if you have them? it’ll be lighter/stronger/etc…
Laminating/skinning a perfectly fine wooden deck with CF is mainly for the look, so strength isn’t my concern, but the weight is. I guess the extra resin and cloth weight should be very minimal I’ll find out. I might do the cutout for the deck to compensate the weight. It depends on how cold my garage is ha
Awesome board Man !!
hey, i was just wondering what technique you used to mount your balancing port (and for other ports for that matter…)? looks like you got some kind of gasket for the 11pin balance port.
found this technique, would this work?
