Hey stewii, I wanted to message you about the ESCape but I cant figure out how to message you on this forum
clic his name and > messages https://monlongboardelectrique.files.wordpress.com/2018/02/sans-titre-1.jpg
Thats what I expect to see, but I dont see any message tab or option. Is it some like new member limitation?
get your read time up bro. contribute, like some posts…
lol, it looks like that one like fixed it o.0 Thanks for the help
Hey, I’m down to take 2 without housing, I believe I put down for 2 with, 2 without
Perfect Stewii ! Any advice to make the two in one ? You let the space between them open or separated ?
Someone need to set up a competition in performance between the ESCape and the VESC6!
There shouldn’t be a measureable performance diff…it is identical
Just scrolled back up and found the link to the form. All completed. Thanks @stewii for providing this service to the community here.
I am asked quite often if a housing is necessary, so I’ve done a quick comparison with alu housing and nothing over the FETs:
notes:
-I had to stop the 60 amps test a bit earlier because my motor which is rated 50A max was starting to smell funny. -the housing was about 20-30 degrees C lower than the FETs -Once the FET temp cutoff kicked in which made the amperage go lower I stopped the test, it only happened in the tests without housing.
Are these available still? If so how do I order? Sorry if this has already been stated a billion times…
the differences in temperature rise are quite obvious on the test … or the utility of a heat sink … Thanks for thé test
Yes, they are, I keep making them, sometimes can take up to 2 weeks, depending how busy I am and if I need to wait for parts to arrive. Just message me if you want to order.
If the ones without housing are still available I’ll take 2 Planning to put them on a dual mount plate
Lifespan of the FETs should be longer if ran cooler
I would like 1 with the aluminum case. Please inform me how to contact you. not sure if this is pm or not.
