Just to buy. Send me a message.
I just signed up on the google sheet and sent a question, GREAT work youāre doing here!
Iāll buy 2 from you if theyāre cheaper than the āb-boxā ones in total
Wow ! so effective Stewii Thanks a lot again and again for all your work and services !!
Thanks. I appreciate it. b-boxes might be cheaper, not sure if bimmer has a final price. If I could afford buying components for 100 units I could make them cheaper but I cant.
iād pay stewii more, b-box is kind of stewii clone with some changes. stewii has a all aluminium case, double case offeredā¦ b-box stewii case/pom/alloy.
b-box is stewii re-design re-designedā¦
how hard do you want to go?
Okay awesome, thanks man
Yeah I am charging 160$ because I only made 50 aswell.
Hey @stewii I purchased 4 pcbs from you and built them up and milled out the casesā¦ Do your top plate pcbs actually have anything on them? As Iām thinking of just laser cutting some ABS or bare silicate board for case coversā¦since I didnāt order cover pcbs(you hadnāt completed them yet)
Thanks
OMG Are they real VESC9?
Cover pcb has a printed 2.4Ghz antenna for the nRF IC and the layout of all the connections, thatās it.
Ah ok thanks man. Iām didnāt populate the nrf and not worried about silk screen.
Thanks dude.
No problem, stl file will be here tomorrow if you want to use it.
Another 3 almost finished. Housings will take a couple of weeks tho. So if anyone is after one without housing let me know.
Whats your soldering setup like? any pics?
No pics, it is a reflow oven mostly and a 100W soldering iron for the cables. I only use the hot air station if I need to desolder something and that doesnt happen often.
ok, super !! Thanks Stewii, hope you take some time or find some to enjoy your WE still. Iām not pressed for time (sorry donāt know if this expression exist in english ā¦) but again, thanks for your work ! I will test it at once tomorow for sure
he gets some practice
