absolutly wonderful! great to see its bullet proof at high erpm
If I aquire a new skill im the process I’m okay with ruining s couple boards I also learned to never order the exact BOM since parts cost fractions of pennies sometimes.
I just taught myself an $80 lesson yesterday trying to make a carvon fiber deck it’s all in the game brother
Yes, but by ordering not exactly the same parts (lower quality for fewer pennies) you might add one extra “O” to the BOM.
I meant order more than exactly them BOM because the little parts are never to be found once dropped and dont break the bank to order 50 instead of 4.
That makes sense.
Hot air I think my stencil was too thick and added to much solder paste…
Hi Stewii,
At those high erpm, are there still any noise differences bewteen BLDC and FOC?!
Thierry
Thank you for the recording. It sounds like a little lower frequency on FOC. stewii are you making any progress? Looking forward to putting it to work.
Update:
With the help of @Stewii, I was able to fix the DRV error.
Everytime I moved the USB plug from the slave ESC a DRV error was stored, at first I thought the cause was a bad DRV or USB plug solder joint.
When I disassembled the ESC I found the temperature wire crooked against all electronics the screws were compresssing it even more against the motherboard.
Once I routed that wire correctly and bolt the ESC back again, BOOM! no more DRV error.
I’m running BLDC at the moment but tomorrow I’ll go back to FOC.
Sorry to all you guys for throwing wrong information about the blow DRV chip.
ESCapes are working amazing so far.
I’d like to anounce that she’s alive.
Update! Thanks stewie for such a great product. I whipped up a quick and dirty battery to bench them and they run great. Ran a 245KV outrunner at fully charged 12S on FOC. full speed, stop, full speed, reverse, back and forth nothing cogging or weird noise and most of all no DRV error.Did you solder it all yourself?
Thanks.
Thierry
That is impressive.
Filled out and submitted the google form.
I hope I’m not too late to jump in on this.
Another update:
I’m back at FOC the ESCapes are working pretty good after temporarily fixing the flexing of the mother board, not a single fault, pretty reliable and fun to run it in FOC.
Highly recommended this ESCape
