My vesc is 5 pins, and my motor is 6 pins? What is the easiest way to convert it to a 5 pin? Also I think my remote is broken, when I ride now it goes slow then full throttle all of a sudden then I let go and 5 seconds after I let go of the throttle it stops. Its the winning remote, I have had it for a while and dropped it many times. Any one have ideas?
VESC is 6 pins
5v TEMP hall1 hall2 hall3 GND
In that order. Replace your remote, the winning remote is notoriously unreliable.
Which Remote would you recommend getting?
What does the sensored plug do?
Thanks for your help with the remotes
mini remote on ebay is like half the price
I got the remote and it wont charge over the one out of three lights. Have you had any charging issues?
what do you mean, it never charges? have you tried a different cable and brick?
Its stays at 1 bar. It keeps breaking up with my board. Are your u from santa monica?
Not sure if I understand your words. Just one light is shining while charging or after charging? At the end of charging all five lights have to shine and it ends with only the upper LED is shining. While using the remote only the lowest LED will shine, that’s normal. And also one of the upper two lights will shine for the mode you choosed. What do you mean with “it keeps breaking up my board”?
I have charged it with several different chargers and it stays like this:
It keeps disconnecting from the board and sometimes it will go full throttle and go by itself. Thankfully it stops after a second. Really frustrating.
If you made the picture after charging without cable and turned on then it is alright. I was also confused with this after I charged my remote the first time. While charging all five lights have to shine or blink.
About the other problem. Be sure your pulsewith in BLDC Tool is set correctly. Click on “Display” and have a look on the green bar (maybe blue if you use mac). Full Throttle must be 100% green bar, full brake is 0% no green bar. Now turn off the remote and the green bar has to be at 50%. If not you have to adjust max and min pulsewith. Btw. with @ackmaniacs firmware 2.54 you also can adjust centre pulsewith, so it’s a bit easier. I would try to rebind the remote with the receiver and for a test try to place the receiver on the outside of the enclosure to be sure there is no problem with shielding. If nothing helps contact your supplier.
