Guys Ive just received two Maytech Vesc, I ordered it from Alien power systems. How Do i connect the Canbus? the cable I was sent doesn’t look like the right one??
One end goes into the Vesc but the other end doesn’t seem to plug into anywhere on the second Vesc.
Am I missing something??
mmaner
March 13, 2017, 10:07pm
2
It should go into the same plug on the opposing VESC, but it only needs 2 wires. Not sure why your lead has 5.
rpn314
3
That is definitely not a cable that will work. Both ends should be the same connector
Edit; That’s not the Can-bus cable anyways. The can-bus connector is the 4-pin connector on the right next to the USB plug.
I think you have the cable for hall sensors in your hand there…
canbus only needs the 2 pins like this cable:
Please use the search function next time first:
The VESC is designed to control dual motors from one input source. It also offers traction control! In the picture below there is one remote control receiver connected via the Orange, Red & Brown Wires. ...
Reading time: 12 mins 🕑
Likes: 71 ❤
Yh I just released thanks, I only asked because I emailed the supplier before hand and they told me they would put in a canbus with my order
IsTalo
March 13, 2017, 11:03pm
7
Man, I have this Vesc and I think it is for a Uart port or a extension for a Sensored motor
Is that the only person who has the Canbus plug?
Diyelectricskateboard has them
FYI: I was just looking for a Canbus cable. DIYelectric’s shipping was like $10 and Ollin’s shipping was $3 (cables were roughly the same price.
you can just use 2 wires and solder them to the board.
