So I left it charging for an hour. It didn’t charge anything anymore. So the cells are still unbalanced. According to that video (what I’ve read before), the bms sheds the voltage of the 4.2 cells so that they lose while the gain, neutralizing each other. But where does that discharge current go?
Again I don’t mean checking the voltage of the cell, but the voltage on the BMS. If you’re saying your getting 3.9 on some of the BMS balance leads then it sounds like the BMS is malfunctioning.
I get nothing. It doesn’t show any voltage between pins of the balance port without being plugged in. And I don’t see why it would, there’s no positive connecting the battery to the bms. The balance leads are that positive. So why would I get any voltage like this?
With the JST unplugged, and the negative from thebattery plugged in, I get nothing, because the circut is incomplete. Theres no positive going into the bms. The only positive meant to go into this bms is balance wires. Which is why I’m confused as to how I would get any voltages without the balance plug plugged in.
The battery is not plugged into anything, including a switch. Was using dyi’s switch, but it was broken. So right now, it’s not hooked up to anything. It’s essentially always on. Does it matter if I removed the switch on the bms? could hat affect anything? cause I never had to turn it on to charge. But could having remove it caused this?
