That’s good you could change the battery?
The battery is soldered on for both, but you could technically change it if you’d like to. They’re both rechargable 1s lipo’s.
Chaka’s motor looks beautiful on that board. And the VESCS… Nice build! What are you doing for an enclosure?
These motors look awesome !
nice!
one remark: I would always bring the belt as close to the motor as possible in order to reduce the motor bearing and lateral motor mount load.
The mount is literally as close as it can be as the carbon fiber plate is already hitting the trucks which is perfect as the belt is firm, yet spongy in tension.
@lox897 The enclosure will be the space cell pro!
Very purdy, I dig it! My build is looking remarkably similar but with just one OBC motor. I’ll be keeping an eye on this thread for when my parts arrive as a building guide haha
nono, i meant something else! basically: turn around the motor pulley and bring the mount closer to the wheel!
Oh i see! Will do, thanks for the tip.
As per @whitepony’s suggestion, I’ve reversed the pulley and plan to (somehow) drill a little notch into the motor shaft for the grub screw. Will also be getting keys for it. I’ve also used a dremel to drill a little notch in the hanger for the mount’s grub screw as well and loctited the mount to the trucks.
Very similar to my drivetrain and power ambitions although I’m only going single motor for now. What pulleys are you using for the wheel? Is that a 9mm setup? Also-- did you order your space cell yet? I think the 3 is in stock but wondering the deal with the 4
I ordered my Space Cell a while back order #36xx. It should be shipping this weekend if what I heard was correct. I’m using DIY’s kegel pulley in 9mm.
Make sure you tape the shit out of that motor before you start dilling … Don’t want those fillings stuck to those magnets
Got it, thanks! I’m not sure how i’m going to drill it so i was thinking of using a dremel cutting wheel to make a small notch. How are you mounting your pulleys?
Sorry for being a complete ignoramous but help me understand why you’re drilling into the motor shaft? Is the pulley from @torqueboards not a simple plug and play (or slipon and tighten) with the OM motor? The mechanics of this situation escape me. I’m planning on going single motor 12mm so wondering if I’ll be up against the same challenge
The key will help the pulley rotate with the shaft, however it’s not secured from sliding around the shaft (toward/away from the motor) so I’d like to drill a small notch for the grub screw to sit so it doesn’t slide around. At least, unless someone tells me it’s not necessary
I see. What about grinding the caliber iis down? I’ve heard that’s likely a situation we’ll both need to tackle. If you do that, post some pix so we know what we’re up against.
You mean grinding the trucks for the Enertion pulley? Or for the mount’s grub screw? I haven’t received my Enertion pulley’s yet so I’m using Kegels w/DIY’s mount that doesn’t need truck modification. As for the grub screw I just stuck my dremel down the hole on the mount (see pic) and drilled a little bit, took off the mount and continued drilling until the grub screw sank into the hole just a little bit (about 1mm).
10-4 on the grub. Since im going monodrive and 12mm belt I’ve read and seen in a video elsewhere on the interwebs that the 3D printed pulley screws thru the kegel 80mm require grinding the caliber shaft a bit otherwise the Bolts of the pulley will rub. Unfortunately DIY doesn’t yet have a 12mm pulley available for those wheels. Pretty tough to find actually
Awesome build! When do you get your spacecell pro4?
