After putting together my first eboard build, when I tried connecting my vesc to the BLDC tool it says connected for about two seconds then it reads “no firmware read response”. I’ve searched around the forum for people with similar problems and tried their solutions but nothing has worked for me so far. If it helps, when I turn it on (with anti-spark key) the vesc doesn’t blink at all, but my voltmeter turns on and reads 0.0.
Any help would be appreciated.
Don’t have access to pics atm,
10s battery
battery support 10s 60a bms
Vesc is diy and was sold to me by @ekitesurfer and was repaired by @JohnnyMeduse
Do you have a link to your voltmeter? If it is a 3 wire meter I think you have it wrongly wired. If 2 wire I think its not working properly. Anyway I think this has nothing to do with the vesc issue. Unless some kind of power mistake damaged both
Many high voltage meters like yours require an auxiliary power source, usually 12-24V, to power the meter itself. One wire is meter power input (12V), one is the voltage reading (~42V), and one is ground
The easiest solution is to buy a 2-wire voltmeter. There are plenty available that can accept 10S voltage
