I am also unable to bind my controller. My steps –
- power receiver with cable to CH1
- power transmitter.
- wait I’ve tried the bind channel, which will bind the remote (lights stop flashing), but no power when throttle up. Any suggestions?? @onloop?
WAIT… more time.
His bound right up. Been connected for 5 min now. Still waiting…
Turn the remote on first, chan1 is the right one
Trying that now. still not binding.
Still nothing. This should be really simple. Anything else I can try?
What’s this button? Does this need to be pressed for first time binding? Maybe mine didn’t get connected at the factory??
Oh. Missed that. thanks. Still I can’t get it to bind. About to give up.
just close everything down for about 5 to 10 min (take a coffee and refresh your mind before giving up ) then retry using the binding procedure.
Bound once. (by chance after sitting 8 hours) Set Min/Max/Center pulswidth seemed to work fine.
turned off board. turned on board.
WONT CONNECT!!! This is infuriating. NOTHING has changed.
Transmitter first –
Receiver (board) First –
Whats the dealio???
can you post some picture
Edit : have you try to reverse you servo connector
Yes. I have, but it connected once and worked once. Then simply after power off, it wont connect again. Pics coming, but you really can’t see much. Vesc side is glued in. Works with mini remote/receiver. Signal wire is on inside, power in middle, ground outside, CH1.
You shouldn’t need to physically change the plug. Not sure what it does when it binds in the bind slot…
Just leave it chan1, and give it a min
I’ve done that. It just won’t connect.
How about a real boring 3min video of it trying to bind on chan1 only, nothing else, just let it blink
Huh… something wrong here, well you have all your evidence to contact support with
I have the new nano-x remote, and I’d like to use in my Raptor 1, from Enertion, (Build, October 2016).
How can I remove the winning Bluetooth console from my board without major surgery? The wires have been set in with black hot glue. On the console as well as on the vesc…
I also want to put connectors on the ends of the wires to make it easier to do this next time…
Reading through this thread does give me some concern though… Will it even work once I’ve went through the trouble of installing the nano?
